The best AI note takers for interviews automate transcription and generate intelligent summaries, freeing you to focus entirely on the candidate. Leading tools like Jamie, JotMe, and Fireflies.ai deliver high transcription accuracy, identify different speakers, and integrate seamlessly with video conferencing platforms such as Zoom, Microsoft Teams, and Google Meet. Their core value is saving time while creating a more objective and detailed record of every interview.
An AI note taker is a software tool that uses artificial intelligence to automatically record, transcribe, and summarize conversations from meetings and interviews. Instead of manually typing notes, these platforms capture the audio, convert it to text, and then use AI to pull out key insights, decisions, and action items. For interviews, this technology is transformative. It allows hiring managers and recruiters to engage fully with a candidate, focusing on nuances in conversation and body language rather than being distracted by note-taking.
There are generally two types of AI note takers: bot-based and bot-free. Bot-based tools, like Fireflies.ai, have a virtual assistant join the call as a participant to record the audio. While effective, some find this intrusive. Bot-free options, such as Jamie or JotMe, capture audio directly from your device's system, operating discreetly in the background without an extra participant appearing in the meeting. This approach is often preferred for high-stakes interviews to maintain a natural conversation flow.
The primary benefits of using an AI note taker during the interview process include:
• Enhanced Focus: Interviewers can dedicate their full attention to the candidate, leading to better evaluation and a more positive candidate experience.
• Objective Records: AI provides a complete and unbiased transcript, reducing the risk of human error or subjective interpretation in manual notes.
• Time Savings: Automating notes and write-ups can save recruiters several hours per week, streamlining the entire hiring workflow.
• Improved Collaboration: Transcripts and summaries are easily shareable with the hiring team, ensuring everyone has access to the same information for debriefs and decision-making.
Beyond simple transcription, many modern AI platforms are evolving into comprehensive productivity copilots. For instance, tools like AFFiNE AI are expanding this concept into a multimodal canvas, where AI helps not just with text but also with generating visuals, mind maps, and presentations from your notes. This allows you to transform raw interview data into polished, shareable content effortlessly, turning concepts into actionable insights for the entire team. For broader team meetings, see our guide to choosing an AI scribe for remote teams.
Not all AI note takers are created equal, especially when it comes to the specific demands of an interview setting. To make an informed decision, it’s crucial to evaluate tools based on a consistent set of criteria. Our testing revealed several key features that separate the best tools from the rest. Prioritize these features based on your team’s specific workflow and security requirements.
A critical feature is Transcription Accuracy. The core function of any note taker is to create a reliable text record of the conversation. The best tools can handle various accents, technical jargon, and multiple speakers without significant errors. Another vital component is the quality of AI Summaries and Action Items. A great tool doesn’t just provide a wall of text; it intelligently condenses the conversation into a concise summary, identifies key takeaways, and extracts actionable tasks. This saves you from having to read the entire transcript to get the gist of the interview.
Speaker Identification is essential, particularly for panel interviews. The ability to automatically distinguish between and label different speakers ensures that feedback and comments are correctly attributed. For workflow efficiency, look for robust Platform Integrations. The tool should connect seamlessly with the video conferencing platforms you already use, like Zoom, Google Meet, and Microsoft Teams. Deeper integrations with Applicant Tracking Systems (ATS) or CRMs, as offered by tools like BrightHire, can further streamline your process by automatically syncing notes with candidate profiles.
Finally, consider Security and Privacy. If confidentiality is a major concern, a "no-bot" solution that doesn't require a third-party participant to join the call might be a better fit. As highlighted by reviews of tools like JotMe and Jamie, these options capture audio locally, offering a more discreet experience. Below is a table comparing some top contenders on these essential features.
| Tool | Transcription Accuracy | AI Summaries | Speaker ID | No-Bot Option | Primary Use Case |
| Jamie | High | Excellent | Yes | Yes | All-around productivity & privacy |
| JotMe | High | Good | Yes | Yes | Multilingual teams & live translation |
| Fireflies.ai | High | Excellent | Yes | Yes | Collaboration & CRM sync |
| Otter.ai | Good | Good | Yes | No | Team collaboration & live notes |
| BrightHire | High | Good | Yes | Yes (Varies) | Hiring & ATS integration |
| Fathom | Good | Good | Yes | No | Free individual use |
After testing numerous tools, we've narrowed down the list to the top performers that are particularly well-suited for interviews. Each tool offers a unique blend of features, catering to different needs from solo recruiters to large talent acquisition teams. Here’s our breakdown of the best options on the market.
Jamie stands out for its bot-free approach and high-quality AI summaries. It captures audio directly from your computer without an intrusive bot joining the call, which is a major plus for maintaining a professional and private interview environment. The platform supports over 100 languages and excels at generating accurate, well-structured notes and action items.
During our tests, Jamie consistently produced clean transcripts and insightful summaries that required minimal editing. Its user interface is simple and intuitive, making it easy to adopt without a steep learning curve. The tool is GDPR compliant and permanently deletes audio files after transcription, offering strong data security.
• No intrusive meeting bot enhances privacy.
• High-quality summaries and accurate action item extraction.
• Strong GDPR compliance and data security practices.
• Does not record video.
• The free plan has limitations on meeting duration.
JotMe is another excellent no-bot solution that shines with its real-time translation and multilingual capabilities. It can transcribe and translate conversations in over 45 languages as they happen, making it an invaluable tool for global recruitment teams conducting interviews with candidates from diverse linguistic backgrounds.
Like Jamie, it runs discreetly on your machine, capturing system audio without alerting other participants. Its AI-generated summaries are available in 13 languages, helping to avoid miscommunication across international teams. The free plan is generous enough to get a good feel for the tool's capabilities.
• Real-time translation in 45+ languages.
• No-bot integration ensures privacy.
• Generates summaries in multiple languages.
• No mobile application is currently available.
Fireflies.ai is a powerhouse for teams that need deep collaboration features and extensive CRM integrations. Its AI bot, Fred, joins your meetings to transcribe and summarize conversations. After the call, you get a detailed summary with action items, and the entire transcript is searchable by keywords, speakers, and topics.
Where Fireflies excels is its ability to sync data with platforms like Salesforce, HubSpot, and Slack, automating post-interview workflows. You can create soundbites from key moments in the interview and share them with your team for feedback. While the bot's presence might be a drawback for some, its robust feature set makes it a top choice for process-driven teams.
• Excellent collaboration features like comments and soundbites.
• Deep integrations with major CRMs and work tools.
• Smart search and topic tracking make finding information easy.
• Requires a bot to join meetings, which can feel intrusive.
• The interface can feel cluttered with features.
For solo recruiters or those on a tight budget, Fathom is an unbeatable choice. It offers unlimited transcription and recording completely free for individual use. Fathom’s AI bot joins your Zoom, Meet, or Teams calls and provides a post-meeting summary with action items. You can also create and share clips from key moments of the interview.
While it may lack some of the advanced analytics or deep CRM integrations of paid tools, Fathom's free plan covers essential features, but limits advanced AI summaries after the first five meetings. The ability to copy and paste fully formatted notes and summaries is a convenient time-saver. It’s a fantastic starting point for anyone looking to try an AI note taker without a financial commitment.
• Completely free for individual users with unlimited recordings.
• Provides all core features: transcription, summaries, and clips.
• Easy to share calls and highlights with others.
• Requires a bot to join the call.
• Lacks advanced features found in paid team plans.
Selecting the 'best' AI note taker is subjective and ultimately depends on your specific needs, budget, and workflow. To make the right choice, consider the key decision factors that will impact your team's efficiency and the candidate's experience. By evaluating your priorities, you can move from a long list of options to the one or two tools that are the perfect fit.
First, evaluate your Budget. Many excellent tools, like Fathom, offer robust free plans that are perfect for individuals or small teams just getting started. Paid plans, such as those from JotMe or Fireflies.ai, unlock advanced features like unlimited transcription, deeper integrations, and enhanced security, which are often necessary for larger teams. Determine whether the time saved and features gained justify the monthly subscription cost.
Next, consider your primary Use Case. Are you exclusively conducting hiring interviews, or do you need a tool for sales calls and internal meetings as well? A specialized tool like BrightHire is built specifically for hiring and offers deep ATS integrations. More general-purpose tools like Jamie or Otter.ai are flexible enough to handle various types of meetings, which might be more cost-effective if your needs are diverse.
Your Team Size and Collaboration Needs are also crucial. Solo users may only need basic transcription and summary features. However, larger teams will benefit from collaborative features like shared workspaces, commenting on transcripts, and the ability to create and share clips, which are strengths of platforms like Fireflies.ai. Finally, assess your Technical and Security Needs. If you operate in a highly regulated industry or simply prioritize confidentiality, a no-bot solution like Jamie or JotMe is likely the best choice. If deep CRM or ATS integration is a must-have to automate your workflow, then a tool like Fireflies.ai or Avoma should be at the top of your list.
To simplify your decision, here is a final verdict based on common needs:
• Best Overall & For Privacy: Jamie
• Best Free Option: Fathom
• Best for Multilingual Teams: JotMe
• Best for Team Collaboration: Fireflies.ai
• Best for Hiring-Specific Workflows: BrightHire
Our recommendation is to identify your top two contenders and take advantage of their free trials or free plans. Testing them in a few real-world interviews is the best way to determine which tool truly fits your workflow and helps you hire more effectively.
The best AI for transcribing interviews offers high accuracy, speaker identification, and handles different accents well. Tools like Jamie, JotMe, and Fireflies.ai are highly regarded for their transcription quality. Specialized services like Sonix also focus specifically on producing accurate transcriptions quickly.
The best AI tool for an interview depends on your needs. For pure note-taking, a tool like Jamie or BrightHire is excellent because it allows you to focus on the candidate. If you need live translation for international candidates, JotMe is a top choice. For teams that need to collaborate on feedback, Fireflies.ai offers powerful sharing and integration features.
The best AI note takers that don't join meetings as a bot are Jamie, JotMe, and Krisp. These tools capture audio directly from your computer's system, ensuring privacy and preventing the awkwardness of a virtual assistant appearing as a participant in the call. This is often preferred for client-facing or sensitive meetings like interviews.
For general note-making, several AI tools excel. Otter.ai is popular for its real-time transcription and collaborative features. Notion AI integrates AI into a broader productivity and database tool, allowing you to summarize and act on your notes. For meetings specifically, tools like Fathom and Jamie are designed to automate the note-making process from start to finish, creating summaries and action items automatically.
