Medical Disclaimer: The information provided in this article is for educational and administrative documentation purposes only and does not constitute medical advice, diagnosis, or treatment. Always adhere to your institution's specific protocols and CMS guidelines.
Ever feel like you're racing against the clock during patient encounters? You're not alone. Clinical documentation demands precision, but time is always in short supply. That's where a well-structured Review of Systems (ROS) template becomes your most valuable ally.
It transforms a potentially chaotic symptom-gathering process into a streamlined approach that catches what might otherwise slip through the cracks. In this guide, we provide a copy-paste ROS checklist, explain the 14 body systems, and break down the latest E/M billing requirements.
Quick Download & Use
Looking for a tool to build your own medical templates? Check out AFFiNE's customizable review templates to digitize your documentation workflow instantly.
If you are looking for a standard Review of Systems checklist to paste into your notes or EHR macros, use this comprehensive 14-system structure.
Constitutional: [ ] Fever [ ] Chills [ ] Weight Loss [ ] Fatigue [ ] Sweats
Eyes: [ ] Blurred Vision [ ] Double Vision [ ] Pain [ ] Redness
HENT (Head, Ears, Nose, Throat): [ ] Hearing Loss [ ] Tinnitus [ ] Ear Pain [ ] Congestion [ ] Sore Throat
Cardiovascular: [ ] Chest Pain [ ] Palpitations [ ] Edema [ ] Orthopnea
Respiratory: [ ] Dyspnea [ ] Cough [ ] Wheezing [ ] Sputum
Gastrointestinal: [ ] Nausea [ ] Vomiting [ ] Diarrhea [ ] Constipation [ ] Abdominal Pain [ ] Melena
Genitourinary: [ ] Dysuria [ ] Frequency [ ] Urgency [ ] Hematuria
Musculoskeletal: [ ] Joint Pain [ ] Stiffness [ ] Swelling [ ] Back Pain
Integumentary (Skin): [ ] Rash [ ] Lesions [ ] Itching [ ] Dryness
Neurological: [ ] Headache [ ] Dizziness [ ] Syncope [ ] Numbness/Tingling
Psychiatric: [ ] Depression [ ] Anxiety [ ] Sleep Disturbances
Endocrine: [ ] Polydipsia [ ] Polyuria [ ] Heat/Cold Intolerance
Hematologic/Lymphatic: [ ] Easy Bruising [ ] Bleeding Gums [ ] Swollen Nodes
Allergic/Immunologic: [ ] Hives [ ] Hay Fever [ ] Frequent Infections
A Review of Systems (ROS) is a standardized inventory of body systems obtained through a series of questions to identify signs and symptoms that the patient may be experiencing.
According to the CMS Evaluation and Management Documentation Guidelines, the ROS serves as a diagnostic safety net. While the HPI (History of Present Illness) zooms in on the chief complaint, the ROS casts a wide net to ensure no underlying pathology is missed.
Research indicates that systematic ROS screening can uncover up to 11% of new problems that patients failed to mention initially. It serves four critical roles:
Diagnostic Accuracy: Catching "red flags" (e.g., weight loss in a back pain patient).
Billing Compliance: Supporting the level of service billed (E/M coding).
Legal Protection: Proving a thorough exam was conducted.
Care Coordination: Creating a clear history for other providers.
A complete ROS covers 14 distinct systems. Below is a guide on what ROS questions to ask for maximum efficiency.
| Body System | Key Screening Questions |
| 1. Constitutional | Fevers, chills, night sweats, or unintentional weight changes? |
| 2. Eyes | Changes in vision, pain, redness, or double vision? |
| 3. ENT | Hearing changes, ringing ears, sinus pressure, or sore throat? |
| 4. Cardiovascular | Chest pain, racing heartbeat, or leg swelling? |
| 5. Respiratory | Cough, wheezing, or shortness of breath (at rest or exertion)? |
| 6. Gastrointestinal | Nausea, vomiting, stomach pain, or changes in bowel habits? |
| 7. Genitourinary | Pain with urination, blood in urine, or frequency issues? |
| 8. Musculoskeletal | Joint pain, stiffness, muscle weakness, or limited motion? |
| 9. Integumentary | New rashes, itching, or moles changing shape? |
| 10. Neurological | Headaches, dizziness, numbness, or fainting spells? |
| 11. Psychiatric | Feeling depressed, anxious, or changes in sleep patterns? |
| 12. Endocrine | Excessive thirst, frequent urination, or heat/cold intolerance? |
| 13. Hematologic | Bruise easily, bleeding gums, or swollen glands? |
| 14. Allergic | Seasonal allergies, frequent infections, or medication reactions? |
To save time, use a "Head-to-Toe" approach or start with Constitutional symptoms (fever/weight loss), as these often flag systemic illness (infection, malignancy) immediately.
A common audit pitfall is confusing the ROS with the Physical Exam (PE).
ROS is Subjective: What the patient tells you (e.g., "My chest hurts").
Physical Exam is Objective: What you measure/observe (e.g., "Tachycardia noted on auscultation").
| Feature | Review of Systems (ROS) | Physical Exam (PE) |
| Source | Patient Interview | Doctor's Observation |
| SOAP Note Location | Subjective | Objective |
| Phrasing | "Patient reports..." / "Denies..." | "Observed..." / "Ausultated..." |
| Example | "Patient denies shortness of breath" | "Lungs clear to auscultation bilaterally" |
Documentation requirements depend on the complexity of the visit. While recent CPT updates emphasize Medical Decision Making (MDM), thorough ROS documentation remains vital for supporting the complexity of your decision.
Used for comprehensive exams (Level V). You must document at least 10 systems.
Example (Chest Pain):
Used for straightforward visits (Level II/III). You only need to document the system related to the problem.
Example (Ankle Sprain):
Many efficient providers list positives and pertinent negatives, then use a summary statement:
"Positive for cough and fever. Negative for chest pain or shortness of breath. All other 10+ systems reviewed and are negative."
Note: Only use this if you genuinely asked the questions.
If a patient is intubated, demented, or unconscious, you cannot obtain a standard ROS.
Documentation: "ROS unable to be obtained due to [patient intubation/dementia]. History obtained from [family member/records]."
Legal Tip: Never make up an ROS. Stating "unable to obtain" protects you more than a fake "all negative."
To speed up this process, clinics are moving to digital templates. Using tools designed for structured data can help. For example, if you struggle with organizing clinical tasks or study notes, using a planner for impulsive tasks can help structure your administrative workflow, while tools like AFFiNE allow you to build custom medical knowledge bases.
Customize: Don't use a generic template for everything. A cardiologist needs a deep Cardio/Resp section; a dermatologist needs a detailed Skin section.
Be Specific: Avoid "ROS Negative." Use "Denies chest pain, shortness of breath..."
Link to MDM: Use your ROS findings to justify your medical decision-making complexity.
Use Macros: Build the 14-point checklist into your EHR text shortcuts.
By mastering the Review of Systems template, you ensure your documentation is audit-proof, your billing is accurate, and most importantly, your patient care is thorough.
The HPI (History of Present Illness) focuses strictly on the story of the chief complaint (e.g., onset, severity of chest pain). The ROS (Review of Systems) is a checklist of other symptoms (e.g., "Do you also have a rash?") that may or may not be related.
Historically, a "Complete" ROS required 10 systems. Under current 2025 guidelines, billing is driven by Time or Medical Decision Making (MDM). However, documenting a complete ROS supports a "High Complexity" MDM by proving the depth of your evaluation.
Yes, this is acceptable for a "Complete" ROS, provided you (1) documented the individual pertinent positives/negatives for the affected systems and (2) actually performed the review of the remaining systems.
It is Subjective. It belongs in the "S" part of your SOAP note because it is based on what the patient tells you, not what you measure.
Study Guide Templates That Cut Prep Time - Organize your medical study notes efficiently.
90 Day Review Templates for Professionals - For tracking professional clinical progress.
Notion Templates For ADHD & Focus - Tools to keep your clinical workflow focused.
