The cybersecurity industry rarely moves in unison. When it does, security leaders should pay attention.
In response to advances in Anthropic's Claude Mythos model, the Cloud Security Alliance CISO Community has joined forces with SANS, [un]prompted, the OWASP Gen AI Security Project, and the wider security community to publish an expedited strategy briefing designed specifically for CISOs.
The advisory outlines a series of steps for security teams to prepare their programs for advances in foundation models, and it is hosted at labs.cloudsecurityalliance.org/mythos-ciso.
It carries one defining call to action: build a deception capability within 90 days. That recommendation is what makes the CSA Mythos Advisory one of the most consequential security documents of 2026.
It reframes deception not as a nice-to-have, but as a necessary control against an entirely new class of AI-driven attacks.
The urgency behind this advisory came from the advances highlighted in the Mythos publications, which triggered a wave of emergency responses across the security community.
The advisory calls for deception as a necessary control to combat advances in vulnerability exploitation stemming from attacker actions involving Mythos or equivalent models.
The briefing was led by three primary authors. Gadi Evron, CEO of Knostic and CISO-in-Residence for AI at the Cloud Security Alliance, worked alongside Rich Mogull, Chief Analyst at the Cloud Security Alliance, and Rob T. Lee, Chief AI Officer and Chief of Research at the SANS Institute.
The contributing authors include a remarkable cross-section of national cybersecurity leadership. Jen Easterly, CEO of RSA Conference and former Director of CISA, contributed alongside Bruce Schneier, a Fellow and lecturer at the Harvard Kennedy School.
Chris Inglis, former National Cyber Director at the White House, joined Rob Joyce, former Cybersecurity Director at the NSA.
Heather Adkins, CISO at Google, contributed alongside Joshua Saxe of Security Superintelligence Labs, Sounil Yu of Knostic, John N. Stewart, formerly of Cisco Systems, and Phil Venables, former CISO of Google Cloud.
More than 250 CISOs edited and redlined this briefing before publication, making it one of the most peer-reviewed security documents of recent years.
The advisory's headline recommendation is direct. CISOs must set a 90-day clock for building deception capabilities to combat the new generation of AI-driven exploitation.
The timeline reflects the consensus view of the authors and 250-plus reviewers that the threat environment has fundamentally shifted.
To plan an effective 2026 security strategy, security leaders need a clear picture of what Mythos actually is.
Anthropic Claude Mythos is the new and currently unreleased general-purpose model from Anthropic.
It has been trained on a large corpus of source code, documentation, and programming languages, with a large set of open-source code included in its training data.
The model carries advanced reasoning capabilities that represent significant advances in multi-step planning and logic.
Anthropic has published an analysis showing the model produces strikingly effective results for cybersecurity use cases, especially around finding vulnerabilities.
Mythos has found thousands of vulnerabilities in major operating systems and browsers, including chained exploits in the Linux kernel and remote code execution in OpenBSD, one of the most hardened operating systems in the world.
Claude Mythos is currently not released in the public domain. Even so, these advances have sparked concern across the industry about what advanced LLM-based reasoning capabilities mean when they fall into the hands of attackers.
The risk splits into two clear categories. The first is volume: Mythos surfaces advances in Frontier AI models in finding and exploiting vulnerabilities at a rate that significantly exceeds previous-generation AI models.
Defenders will use Mythos-equivalent models to find vulnerabilities ahead of attackers, but the attacker continues to have an advantage because they can leverage Frontier AI models that defenders do not have access to.
The second is zero days. One of the key advances in Claude Mythos is the ability to find unknown exploits, or zero days, with novel exploits in both open-source and closed-source software.
By definition, a zero-day exploit does not have an associated patch when it is discovered, which means patching the system is simply not a practical option.
The advisory is blunt about the limits of legacy security controls. EDR and reactive systems are not built for the threat Mythos represents.
As the exploitable set of vulnerabilities grows, defenders find it increasingly difficult to keep patch application levels consistent with the threat.
Patching applications has always been difficult, and the backlog grows far more rapidly with the volume of patches that need to be applied.
As patches lag, an attacker outside the organization can leverage a Mythos-equivalent Frontier AI model to exploit vulnerabilities in internet-facing assets and gain initial access. Once the attacker is inside, propagation across the network occurs at machine speed.
The advisory walks through a concrete scenario. A Mythos-equipped attacker finds and exploits a novel vulnerability in an internet-facing asset and gains remote code execution.
From there, the attacker finds a zero-day in a switch and a hypervisor, then encrypts the hypervisor.
This attack bypasses prevention controls because it is a zero-day with no available patch. The switch and hypervisor are incompatible with agent-based security solutions like EDR, so the attack also bypasses detection controls. The breach is complete.
This attack path is not new and has been flagged in several security reports. What is new is that the high skill level required to perform it would previously have made it look like a corner case.
With Mythos surfacing zero days, the risk associated with this path increases by an order of magnitude.
EDR and reactive controls are designed to combat the human adversary. They observe incoming activity, form a baseline, flag deviations, and look for known patterns. This work takes time, often hours or days.
Mythos-equipped exploits occur within minutes and vary with each execution cycle. The result is slow reactive controls, non-confirmatory alerts, and a loss of the confirmatory signals teams rely on for response.
This is where the advisory's deception recommendation enters the picture, and why it carries such weight.
The advisory highlights deception as a security control that is independent of specific vulnerabilities or attack TTPs.
As attackers leverage Mythos-equivalent AI models to find and exploit zero-day vulnerabilities with no associated patch, defenders need controls that can detect and deflect attacks regardless of the specific exploit techniques involved.
Deception holds a unique position in the security stack because it can detect and deflect these threats without depending on a priori knowledge of the exploit.
By deploying decoys that form a shield around real assets, defenders gain early warning of incoming exploits and, more importantly, deflect them away from the actual assets.
Vulnerability exploits can be performed against assets across workload types, including IT and Cloud environments.
Since Mythos-equivalent models can find vulnerabilities across a wide variety of operating systems, browsers, and applications, they apply to a broad spectrum of assets.
In theory, defenders can deploy deceptions across all asset types to combat Mythos-equipped attackers.
In practice, however, the time-sensitive nature of the exploit risk means defenders need clear criteria for rolling out deception to gain maximum benefit within the 90-day window.
The CSA Mythos Advisory is not a theoretical paper. It is a peer-reviewed, multi-organization consensus document from the most respected names in cybersecurity, and it is asking every CISO to make a structural change to their program before 90 days are out.
If your 2026 security plan does not yet include a serious deception capability, this advisory is the strongest signal you will get all year that it should.
Reactive controls bought time against human attackers, and they will not buy the same time against Mythos. The 90-day clock has already started.
